Help identify a case
philipus
Hi everyone
What is this case called? I've seen similar ones called "outfit" cases but they have had different interiors.
Were these custom-made to fit certain outfits/sets of equipment?
Cheers and thanks in advance
Philip
ETGUS? (So from the Leica Wiki, though I recall there was an earlier forum discussion in which a mistake was suspected).
I bought one last year, but had to return it. It was in poor condition (and also would not fit the taller IIIg).
All best.
Hi everyone
Philip
I confirm that the illustrated case is an ETGUS for Leica (II to IIIb), 5 lenses, VIDOM, frame finder, filters, cassettes. The slightly higher Leica IIIg and outfit could be arranged in the much rarer EBKOO dating from 1958.
Thanks very much for your replies, I appreciate your help a lot.
I looked in the Wiki but the ETGUS there has an second lens strap in the middle.
The filter pockets on the left side are also different
The top-right-hand corner pocket for the FIKUS is also different. The Wiki's ETGUS has a double filter pocket there whereas my case has a longer pocket, similar to (though shorter than) the SOOPD pocket.
Could these cases be changed after purchase by Leica?
Here is a better image perhaps.
can be EHOOB
