lagrassa Posted May 25, 2010 Share #1 Posted May 25, 2010 Advertisement (gone after registration) Does anyone here know if a FOOKH hood can be used together (in front of) a push-on A- type filter which also has the set screw on the side of the mounting ring? Thanks for any information provided. Link to post Share on other sites More sharing options...
Advertisement Posted May 25, 2010 Posted May 25, 2010 Hi lagrassa, Take a look here FOOKH Question . I'm sure you'll find what you were looking for!
giordano Posted May 25, 2010 Share #2 Posted May 25, 2010 If you mean the ordinary A36 filters made by Leitz, the answer is yes: the front part of the filter is the same diameter as the rim of the lens, so you can stack them ad infinitum. Link to post Share on other sites More sharing options...
Xmas Posted May 25, 2010 Share #3 Posted May 25, 2010 Hi I think a FOOKH is just like a FISON in that respect, apart from being more expensive... Noel Link to post Share on other sites More sharing options...
lagrassa Posted May 25, 2010 Author Share #4 Posted May 25, 2010 John, Noel: Thanks for the responses. Yes, I do mean the Leitz A36 filters. Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 27, 2010 Share #5 Posted May 27, 2010 John, Noel: Thanks for the responses. Yes, I do mean the Leitz A36 filters. Yes, no problem... sufficient to make the 2 screws not to interfere one to each other... ... same applies to FISON and FIKUS Link to post Share on other sites More sharing options...
