FiZZ Posted May 24, 2010 Share #1 Posted May 24, 2010 Advertisement (gone after registration) So my version 1 35mm 'cron has a serious vignette when I shoot at f/2. Not complaining, but is this a characteristic of the lens? Link to post Share on other sites More sharing options...
Advertisement Posted May 24, 2010 Posted May 24, 2010 Hi FiZZ, Take a look here 35 'cron Vignette? . I'm sure you'll find what you were looking for!
luigi bertolotti Posted May 24, 2010 Share #2 Posted May 24, 2010 Erwin Puts - Leica Lens Compendium - on the 1st Summicron 35 : .." at full aperture vignetting is 2.5 stops and at aperture 2.8 is 2 stops.." No much changed with the 2nd version (same source) : ..." Vignetting is high with more than 2.5 stops, but the lens is distortion free"... Then the 3rd version: ..." Vignetting is lower with less than 2 stops, but now some distortion is visible..." Then the legendary 4th version : ..." Vignetting is high with 2.5 stops and distortion is not visible..." ...and finally the ASPH ! : ..." Vignetting is lower with 1.8stops and distortion is only visible at the far out zones..". Of course, less noticeable on the cropped M8... Link to post Share on other sites More sharing options...
Xmas Posted May 24, 2010 Share #3 Posted May 24, 2010 So my version 1 35mm 'cron has a serious vignette when I shoot at f/2. Not complaining, but is this a characteristic of the lens? Can you scan a corner with uniform illumination like a sky, were you using a filter and/or a hood? Noel Link to post Share on other sites More sharing options...
