rjjackson Posted April 1, 2010 Share #1 Â Posted April 1, 2010 Advertisement (gone after registration) Hello, Â I have a quick question about identifying a Summaron. Can one know with certainty from the serial number whether the lens is an "M2" version or an "M3/goggles" version? Does 1662xxx give enough information to know which version lens should be? Â thanks, Â RJ Link to post Share on other sites More sharing options...
Advertisement Posted April 1, 2010 Posted April 1, 2010 Hi rjjackson, Take a look here Summaron 35/2.8 identification. I'm sure you'll find what you were looking for!
andybarton Posted April 1, 2010 Share #2 Â Posted April 1, 2010 Well, according to one of the many serial number websites, LeicaLenses serial number and production year - Leica Objektiv Serienummer it was made in 1959. That doesn't narrow it down at all, as both M3s and M2s were made in 1959 Â If it's an M3 with goggles version, it will be obvious, but the M2 versions are much rarer as they have the amended cam in the mount to bring up the 35mm frame on the M2. Â I have had two f2.8 Summarons and a f3.5 version in my time. Neither of the f2.8s were M2 versions, but it doesn't actually matter much, as the 35mm frame virtually fills the whole viuewfinder in an M2 anyway. Â A clean f2.8 Summaron is one of those Leica lenses that performs way, way above the small amount of money that it costs. Link to post Share on other sites More sharing options...
UliWer Posted April 1, 2010 Share #3 Â Posted April 1, 2010 ... Can one know with certainty from the serial number whether the lens is an "M2" version or an "M3/goggles" version? Does 1662xxx give enough information to know which version lens should be?... Â Definitely no. Â All you find in published sources is that No. 1662.001 to 1668.000 were 2.8/35 Summarons from 1959 - a part of them with and the other without goggles. Link to post Share on other sites More sharing options...
rjjackson Posted April 2, 2010 Author Share #4 Â Posted April 2, 2010 Thanks for the help, guys. Â RJ Link to post Share on other sites More sharing options...
jc_braconi Posted April 2, 2010 Share #5 Â Posted April 2, 2010 in 1959 : 1196 SM, 2499 BM, 4046 M3 build. Link to post Share on other sites More sharing options...
rjjackson Posted April 2, 2010 Author Share #6 Â Posted April 2, 2010 JC, Â Are these production figures you are giving? Do you have blocks of serial numbers dedicated to those production figures? Â RJ Link to post Share on other sites More sharing options...
jpattison Posted April 2, 2010 Share #7 Â Posted April 2, 2010 Advertisement (gone after registration) RJ, I'm intrigued as to why you ask your original question. Surely if you can see the lens, or a photo, or description of it, it should be obvious. Â John Link to post Share on other sites More sharing options...
rjjackson Posted April 2, 2010 Author Share #8 Â Posted April 2, 2010 Hi John, Â It's an item for sale from a dealer who does not have quick access to the item for inspection. It is in storage and ships from a different center than their customer service place. The description neglected to specify M2 or M3 version, and this had both me and the representative at the dealer stumped. We both hoped the answer could be solved with the serial number. Â Â RJ Link to post Share on other sites More sharing options...
Freelander Posted April 2, 2010 Share #9 Â Posted April 2, 2010 I have a goggled version I use on my 2007 MP. The goggles just adjust the 50mm frames and works just fine for me. If it helps my Summaron is 1731xxxxx Link to post Share on other sites More sharing options...
jc_braconi Posted April 2, 2010 Share #10 Â Posted April 2, 2010 Hi John, Â It's an item for sale from a dealer who does not have quick access to the item for inspection. It is in storage and ships from a different center than their customer service place. The description neglected to specify M2 or M3 version, and this had both me and the representative at the dealer stumped. We both hoped the answer could be solved with the serial number. Are these production figures you are giving? Do you have blocks of serial numbers dedicated to those production figures? Â RJ 1st The Summaron 2.8/35 for M3 wear a fixed (screws) goggles on. The one I have is for M2 / M4 and is s/n 2 153 7xx made in 1965. 2nd this number do not specify the s/n Hope it will help Link to post Share on other sites More sharing options...
