| Film Forum The Film Forum is about everything regarding non-digital 35mm photography - films, dark room and slide projection |
#1 (permalink) |
Erfahrener Benutzer
Used to get this film processed by Ilford but now starting to do my own. I used Ilfosol.3 1-14 with regular inversion for 6 mins. Ilford recommend this or 1-9 for 4 mins which seemed too short and could lead to uneven development or 1-14 for 6 mins as I did. The negs look OK but a touch pale, however I haven't printed any as yet. Comments very welcome thank you
__________________
"There is nothing worse than a brilliant image of a fuzzy concept."- Ansel Adams Regards Kenneth |
| Advertisement (gone after free registration) |
#2 (permalink) |
Erfahrener Benutzer
The digital truth site gives a time of 4.5 minutes, which is still rather short. An alternative would be to switch to D76 or Xtol which give longer development times. The data on digital truth for Pan F is here...
Digitaltruth Photo: The Massive Dev Chart |
#3 (permalink) | |
Erfahrener Benutzer
Quote:
Steve, this may sound like a numb afterthought but would the results have more definition if I had given the same dilution, say 9 mins?
__________________
"There is nothing worse than a brilliant image of a fuzzy concept."- Ansel Adams Regards Kenneth Last edited by kenneth; 16.06.2009 at 03:52. Reason: additional information |
#4 (permalink) |
Benutzer
What pleases you may not be to my taste, and I admit I do not shoot much Pan F.
Given that you have two times for Pan F @ 50 ASA that differ by 30% you should try shooting a strip of images, a bracketed series repeated several times. When it comes to developing you should cut the film into two and develope one strip for 6 min, the other for 4.5. You'd then have something better to judge from and see what gives a decent print. I don't use Ilfosol, I use R09 (old Rodinal) for the slow & medium speed stuff. I like that because the dilutions can be 1:25, 1:50 or even 1:100 for a short roll. This is my personal taste you understand. I am not trying to 'diss' what you are doing. It may take more experimentation before you get a result you are really pleased with. I am going through the same process with Fomapan 200 and 400 in Ilfotec LC29. With experimentation we aim to reach a point at which we can tell what times suit the film and we can be happy in using them in the knowledge that valuable images are going to develope in a predictable manner. It may be that a cut of 10% for a film shot in sunny conditions might be advisable. |
#6 (permalink) |
Erfahrener Benutzer
I've been using PanF in bright sunshine developed in Rodinal.
Excellent negs finally! See the results in the People Photo Forum. I'll explain my process if there's any interest. Rolo
__________________
Rolo "Only the Brits put on their best Sunday suits, roll up their trousers and walk into the sea." ~ Elliott Erwitt Some of My Images |
#7 (permalink) |
Erfahrener Benutzer
The best and quickest way to establish correct exposure index and development time in one go is to make a series a shots of a non reflective uniformly colored surface and measure the resulting densities. There should be nine exposures, starting with one being four stops underexposed, and then increasing the exposure by one stop until you reach four stops overexposure. If you can't measure the densities, send the negatives to me and I will measure for you and give you my verdict on your exposure index and development time.
But why Pan-F when there is Delta 100 and Tmx 100? |
#8 (permalink) | |
Erfahrener Benutzer
Quote:
I guess I used to use it many years ago and I found it was still available when I returned to using B&W. I do also quite like the sort of traditional look it has and it is completely different to Kodak Tri-X 400 which is the other film I use. Thank you for your kind offer by the way, I may take you up on that
__________________
"There is nothing worse than a brilliant image of a fuzzy concept."- Ansel Adams Regards Kenneth Last edited by kenneth; 17.06.2009 at 02:11. Reason: spelling |
#9 (permalink) |
Erfahrener Benutzer
I love PanF+ and use it typically with Xtol 1:1 for 7.75m @ 68F. Both 135 and 120.
__________________
Leica M8 & Zeiss Ikon - CV 1,2/35 Nokton, ZM 4/18 Distagon, 2,8/25 Biogon, 2/35 Biogon, 1,5/50 Sonnar and 2/50 Planar, Leica 2,8/90 Elmarit-M... |
#10 (permalink) | |
Gesperrt
Quote:
ILFORD Pan F plus processed with Ilfosol is like a Porsche with VW Polo tyres ![]() Pan F plus with Ilford ID11 is the DreamTeam ![]() or Pan F plus (25 ASA) and Ilford Perceptol wls |
#13 (permalink) | |
Gesperrt
Quote:
.....just a sample for inspection Pan F plus and Ilford ID11 Leica R7 and Summicron 2/35 wls btw: no problem for a print 60x90 cm ![]() |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
