Bigfeet Posted April 6, 2009 Share #1 Â Posted April 6, 2009 Advertisement (gone after registration) Greetings All, Could someone give me an idea as to what may be wrong with my camera? These images are from using several different lenses as well as rolls of film. It seems that light is intruding on both the left and right sides. It does show up on the negatives very clearly. Â It also only seems to show up during daylight. Â Any and all help is appreciated. Â Â Thanks! Bigfeet Link to post Share on other sites More sharing options...
Advertisement Posted April 6, 2009 Posted April 6, 2009 Hi Bigfeet, Take a look here Need Help With Possible Camera Issue. I'm sure you'll find what you were looking for!
poynterama Posted April 7, 2009 Share #2 Â Posted April 7, 2009 It's not an R4 is it? Link to post Share on other sites More sharing options...
Bigfeet Posted April 7, 2009 Author Share #3 Â Posted April 7, 2009 It's not an R4 is it? Â Sorry, no it is a M2. Â Â Bigfeet Link to post Share on other sites More sharing options...
andybarton Posted April 7, 2009 Share #4 Â Posted April 7, 2009 Light seal around the rear door? Link to post Share on other sites More sharing options...
Michael Hiles Posted April 7, 2009 Share #5 Â Posted April 7, 2009 I once had a similar problem in my M2. The shape was different, and it was (apparently) intermittant. Like your problem, the leak occurred always in the same place, and overlapped two frames. Â It turned out to be a light leak around the small rewind lever on the front of the camera. Gerry Smith at Kindermann in Toronto found and fixed the problem (BTW - he is terrific). Link to post Share on other sites More sharing options...
Bigfeet Posted April 7, 2009 Author Share #6  Posted April 7, 2009 I once had a similar problem in my M2. The shape was different, and it was (apparently) intermittant. Like your problem, the leak occurred always in the same place, and overlapped two frames. It turned out to be a light leak around the small rewind lever on the front of the camera. Gerry Smith at Kindermann in Toronto found and fixed the problem (BTW - he is terrific).  Thanks for that feedback. I would have never of thought a leak there was possible.   Bigfeet Link to post Share on other sites More sharing options...
acanalda Posted April 7, 2009 Share #7  Posted April 7, 2009 Advertisement (gone after registration) Hi  Have you tried to put the camera in front of a strong light with the back door open ?  Don't forget to fire the shutter and also re-cock it to check possible light leaks in the curtains  Regards,  Arturo Link to post Share on other sites More sharing options...
