leicatwins Posted March 14, 2008 Share #1 Posted March 14, 2008 Advertisement (gone after registration) Hi, I am still learning about film photography. I read somewhere about "push" and "pull" of ISO of certain film. What does it effect? Why people do it? I know my friend likes to use an ISO different from the actual one. Thanks for any share of knowledge. Difi Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2008 Posted March 14, 2008 Hi leicatwins, Take a look here What is push pull in film? . I'm sure you'll find what you were looking for!
rubenkok Posted March 14, 2008 Share #2 Posted March 14, 2008 Hi Difi, Maybe this is some help: Push processing - Wikipedia, the free encyclopedia All the best Ruben Link to post Share on other sites More sharing options...
leicatwins Posted March 14, 2008 Author Share #3 Posted March 14, 2008 Thanks Ruben Link to post Share on other sites More sharing options...
Kent10D Posted March 14, 2008 Share #4 Posted March 14, 2008 As the Wikipedia entry that Ruben linked to says, photographers push film when they need a higher speed for low light work or so they can use a shorter exposure to stop fast action. It also produces a more contrasty look, if that's what you want for artistic purposes. "Pushing" the film implies underexposing it, and then over-developing it to compensate. The reasons for pulling the film are obviously going to be different. When you "pull" a film you're essentially overexposing it, and then under-developing it to compensate. This has the effect of bringing out more shadow detail than you'd get with normal exposure, sometimes at the expense of highlight detail. Quite a few film shooters pull Tri-X, treating it as an ISO 200 film. This results in a tonal range that some people prefer. Lots of room for experimentation ... which is part of the fun of using film. Link to post Share on other sites More sharing options...
innerimager Posted March 14, 2008 Share #5 Posted March 14, 2008 When applying this to chromogenic B&W- When folks use XP2 and set it at ISo 200 in camera rather than 400, do they then ask the lab to develop it at Iso 200? When I set it at 200 I have been developing normally and basically getting a +1EV exposure compensation. Thanks...Peter Link to post Share on other sites More sharing options...
Michael Hiles Posted March 14, 2008 Share #6 Posted March 14, 2008 When applying this to chromogenic B&W- When folks use XP2 and set it at ISo 200 in camera rather than 400, do they then ask the lab to develop it at Iso 200? When I set it at 200 I have been developing normally and basically getting a +1EV exposure compensation. Thanks...Peter XP2 is processed in C41 (colour negative processing), almost always done by a lab in a commercial machine. In that case there is no opportunity to adjust the process. In addition, Ilford in ther data sheet say that XP2 can be successfully exposed for a wide variety of ISO ratings (50 to 800) - and should always be processed the same way, regardless of the exposure rating. So no tinkering and no decisions. For what it's worth, I use XP2 almost exclusively, and I expose as for 200 ISO. I came to this conclusion by doing a standard film speed test, the one found in all Zone system explanations. The idea is to expose so that the darkest part of the scene produces a perceptable density on the negative. That way you will retain the details in the dark part of the scene, and in almost all cases get a negative with maximum information for printing. It also - in XP2 - has the advantage of slightly reducing the effect of grain. And the negatives scan very well and print georgeously. Link to post Share on other sites More sharing options...
innerimager Posted March 14, 2008 Share #7 Posted March 14, 2008 Advertisement (gone after registration) Thanks a lot Michael. That's exactly what I thought, I just wanted to have it confirmed. I'm very happy with the results I'm getting from XP2 at 200 iso, and plan on trying 800 in certain situations. best....Peter Link to post Share on other sites More sharing options...
