martha Posted January 28, 2010 Share #1 Â Posted January 28, 2010 Advertisement (gone after registration) I am a Kodak HIE fan. Sadly, as you all know, HIE is no longer made and difficult (if not impossible to find in the US.) Â Has anyone used the Efka and/or the Rollei infrared film? Please, any thoughts and experiences would be wonderful. (Will be using my M3 or M6 with either a B&W 90/91--red filters--or B&W 93--black--filter.) Â Thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted January 28, 2010 Posted January 28, 2010 Hi martha, Take a look here infrared film. I'm sure you'll find what you were looking for!
marcg Posted January 29, 2010 Share #2 Â Posted January 29, 2010 Off topic but have you seen this? BBC - Viewfinder: On a different wavelength: 100 years of infrared photography Link to post Share on other sites More sharing options...
martha Posted January 29, 2010 Author Share #3 Â Posted January 29, 2010 No, I hadn't seen it, Marc. Thanks for the reference. Â Still awaiting any shared experience with Efke/Rollei IR films. Link to post Share on other sites More sharing options...
chris_livsey Posted January 30, 2010 Share #4 Â Posted January 30, 2010 As no one is stepping forward can I suggest you search here ?:APUG English Forums - APUG Â Â I Link to post Share on other sites More sharing options...
fotohuis Posted January 30, 2010 Share #5 Â Posted January 30, 2010 Rollei IR 820/400, Retro 80S, Retro 400S, Super Pan 200 and Efke IR820 (iso 100) can all be used for IR photography. I am using a Heliopan RG715nm filter for these films. I prefer Rollei IR 820/400 (iso 12) and Super Pan 200 (iso 6) with above filter. Also a good filter is Hoya 72R (720nm) for these films. Rollei IR 820/400 is sensitized till 820nm, all other Rollei films 750nm and the Efke also 820nm but very slow speed, iso 1,5. Â IR effect with a red filter is not possible. You can load and unload all above films in very subdue light. The correction you have to made for the distance is vey small and neglectible if working with a wide angle lens. Development can be done in the regular way with different developers, without any problem. Â Best regards, Â Robert Link to post Share on other sites More sharing options...
Xmas Posted January 30, 2010 Share #6  Posted January 30, 2010 Hi  An M8 is really useful for IR photography, the M9 is less sensitive...  Noel Link to post Share on other sites More sharing options...
martha Posted February 2, 2010 Author Share #7 Â Posted February 2, 2010 Advertisement (gone after registration) Thanks Chris, Robert and Noel. Link to post Share on other sites More sharing options...
Guest maddoc2003jp Posted February 2, 2010 Share #8 Â Posted February 2, 2010 This one was taken with Rollei IR400 and a 2R red filter. Â Link to post Share on other sites More sharing options...
martha Posted February 2, 2010 Author Share #9 Â Posted February 2, 2010 Wow! Nice image Mad doc! Â I tested Efke both with a B&W dark red and a B&W 93 (opaque) and the 93 filter gave more of an infrared effect, although it was slow, slow, slow shutter spead. The dark red did not appear to give any infrared effect. Â I am going to try the Rollei film. Â thanks all. Link to post Share on other sites More sharing options...
christoph_d Posted February 2, 2010 Share #10 Â Posted February 2, 2010 Hi Martha, Â I've been using Rollei SuperPan 200, as well as Rollei IR 820/400 and Efke IR820 (iso 100) on occasion. Â SuperPan 200 is not very sensitive in the real IR spectrum, so just like Robert I've been using dark red filters, Heliopan 715, or B&W 092. As you are probably aware, the amount of IR available is stongly dependent on factors such as the time of day and the visibility of the sky. I've consequently had good results with this film exposing between ISO 6 and ISO 25. Â Efke IR820 should be usable with dark red filters or black-filters (e.g. B&W 093) as its spectral sensitivity reaches into the true IR. I expose between ISO 3 and 6. Â I understand that none of these films reaches as far into the IR spectrum as the HIE did. Also, the lack of a anti-halation backing creates the typical halation effects of the HIE, missing with the other films. Â Best regards, Â Christoph Link to post Share on other sites More sharing options...
christoph_d Posted February 2, 2010 Share #11 Â Posted February 2, 2010 Here a small example with Rollei Superpan 200 and darkred filter (B&W 092). Â Rgds Christoph Link to post Share on other sites More sharing options...
martha Posted February 2, 2010 Author Share #12 Â Posted February 2, 2010 Thanks, Christoph for your input. I have been testing the Efke and only got IR effects with a 93 filter. I don't own a 92, but my 91 gave pretty negligable IR effects. Â I am in mourning for the HIE, which was, as you say, much more sensitive to infrared spectrum. Link to post Share on other sites More sharing options...
