mdt2 Posted March 3, 2009 Share #1 Posted March 3, 2009 Advertisement (gone after registration) All, I am searching for a technique/process to convert my color photos to BW and still be able to brush the original color back into selected areas. I am using CS4. Thanks! Mike Link to post Share on other sites More sharing options...
Advertisement Posted March 3, 2009 Posted March 3, 2009 Hi mdt2, Take a look here Color/BW Technique . I'm sure you'll find what you were looking for!
MV8 Posted March 3, 2009 Share #2 Posted March 3, 2009 Hi Mike, Using a Black & White adjustment layer in Photoshop works great, have you tried that? Link to post Share on other sites More sharing options...
mdt2 Posted March 3, 2009 Author Share #3 Posted March 3, 2009 No I haven't. Is there somewhere that spells out the steps for this technique? Thanks! Link to post Share on other sites More sharing options...
andybarton Posted March 3, 2009 Share #4 Posted March 3, 2009 You need to buy a copy of Adobe Photoshop CS4 for Photographers: Martin Evening. It really is the bee's knees for learning PS techniques. Very basically, create a new adjustment layer using the half black/half white circle in the layers palette. Obviously, choose the "black and white" option. [ATTACH]129924[/ATTACH] Make the adjustment to the sliders to your b&w taste Then, choose a soft paint brush from the tools palette, making sure that the colour in the foreground on the tools palette is black, [ATTACH]129925[/ATTACH] and paint over the adjustment layer with the black paint. This will reveal the colour image below. Here is an original shot (I chose a colourful one ) [ATTACH]129927[/ATTACH] And here it is with a black and white adjustment layer added, then black painted over the adjustment layer. You can see on the layers palette the black line where I have painted, and the effect on the image [ATTACH]129928[/ATTACH] Link to post Share on other sites More sharing options...
mdt2 Posted March 3, 2009 Author Share #5 Posted March 3, 2009 Excellent I'll give it a try, thanks! Also thanks for the tip on the book. There are SO many out there I never know which one to buy. Link to post Share on other sites More sharing options...
roguewave Posted March 4, 2009 Share #6 Posted March 4, 2009 Nicely demonstrated Andy. Mike, just a small note. Evening's book is very good. I also recommend Scott Kelby's 7 point system as he describes several ways to accomplish the same ends. One thing to contemplate & consider is how to save the work you do in the B&W conversion layer. Since storage is now so cheap, I'd recommend not flattening the file, but leave the adjustment layers intact so you can always go back & make changes. Yes, our aesthetic changes and as you get more adept you may find yourself revisiting your work to make changes. You have been well counsel by Andy and are well on the way down the right path. Good luck & remember to post some of your results here to help others learn the same skills. Link to post Share on other sites More sharing options...
andybarton Posted March 4, 2009 Share #7 Posted March 4, 2009 Advertisement (gone after registration) The painting over of adjustment layers with black technique, works with all of them in the same way. If you have done too much, paint the effect back with "white paint". You can paint back 50% of the effect (or remove 50% of the effect) buy adjusting the flow of the paint by 50% (or any other percentage) You can spend years playing with this stuff... Link to post Share on other sites More sharing options...
mdt2 Posted March 4, 2009 Author Share #8 Posted March 4, 2009 Thank you one and all for all your help and advice! Link to post Share on other sites More sharing options...
cmdrfire Posted March 22, 2009 Share #9 Posted March 22, 2009 I've done this with a few images now: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! This is probably quite a crude way of doing it but it works. I use Photoshop CS4. First create a new layer which you make black and white as you like. Make a second layer - the colour layer - which is below the B&W layer. Remove visibility on the B&W layer, select the colour you want to see through, put B&W visibility back on, and use a small eraser with 100% hardness (I use a circular size 13) to erase out the colour, turning off visibility of the B&W layer every now and then to check I'm getting what I want through. It's quite effective, does not take too long, and the results are quite good (I think). Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! This is probably quite a crude way of doing it but it works. I use Photoshop CS4. First create a new layer which you make black and white as you like. Make a second layer - the colour layer - which is below the B&W layer. Remove visibility on the B&W layer, select the colour you want to see through, put B&W visibility back on, and use a small eraser with 100% hardness (I use a circular size 13) to erase out the colour, turning off visibility of the B&W layer every now and then to check I'm getting what I want through. It's quite effective, does not take too long, and the results are quite good (I think). ' data-webShareUrl='https://www.l-camera-forum.com/topic/78417-colorbw-technique/?do=findComment&comment=849447'>More sharing options...
underground Posted March 27, 2009 Share #10 Posted March 27, 2009 Does anyone know if this is posable with aperture? Or of any plug-ins that might do this? Link to post Share on other sites More sharing options...
Guest joewehry Posted March 29, 2009 Share #11 Posted March 29, 2009 Yes it is possible in Aperture, but depends on the shot and is not as precise as photoshop. In the example above, you would have to desaturate all color channels except the red in the sign, leaving the red alone. since there will be some red in the flesh tones (and elsewhere), you may have to reduce the target color so that only that red stays while other reds wash out. Play with the color levels in the adjustment pane. But Aperture offers a round-trip Photoshop export and reimport option. Link to post Share on other sites More sharing options...
