M6 Viewfinder patch image
wide.angle
x
It's not normal but doesn't necessarily mean that the finder will be inaccurate (but I could see how it will hamper focussing with some subjects). Personally, I would send it in to be readjusted. If the M6 hasn't been serviced in recent years you may as well send it in for a full CLA.
I had the same problem with my M6, again it focussed correctly though. I took mine into Leica in Milton Keynes who carried out the adjustment very quickly while I waited - not sure where you are located but if you are in the UK definately worth a call.
Dan
The vertical alignment is actually a very simple procedure, the trick is getting to the adjustment screw. On all M's except the ones with red dot between the rangefinder windows: remove the small screw next to the frosted finder window - this will expose a small adjustment screw inside the body.
By turning this adjustment screw you can 'move' the RF image vertically, until both images coincide. Use only light pressure on the screwdriver; just enough to turn the screw.
Bodies with the red Leitz or Leica dot are a little trickier, as the dot has to be removed to access the adjustment. The dot is glued on and can be damaged in the process however, replacements ara available from Leica.
The whole procedure should not take more than 10 minutes.
All the best,
Jan
Dan, Mine was $300 and change. I guess that's called not in warranty.
Bill,
Surely the $300.00 must have included other work as well, or parts replacements. If you indeed paid that for just the vertical alignment and nothing else, I would complain bitterly....... The top plate of the camera does not even have to come off for this.
I am not a trained Leica technician (actually far from it, more of a "self-taught tinkerer") and have never spent more than 30 minutes on the vertical alignment.
All the best,
Jan
