cbretteville Posted October 16, 2006 Share #1 Â Posted October 16, 2006 Advertisement (gone after registration) Hi, I do a lot of shooting close to the ground and was wondering if anyone has experience with the using the Anglefinder M when not shooting macro subjects. Â - Carl Link to post Share on other sites More sharing options...
marknorton Posted October 16, 2006 Share #2 Â Posted October 16, 2006 All depends on what focal lengths you are using. On an M6, 90mm is fine, 50 is OK if you move your eye around a bit (I wear glasses). With the M8, I expect 50 - 90 will be fine but it's happiest when using the 90mm frame. Â The fancy prism ("Bauernfeind") is quite interesting - there are two internal reflections in it to provide an uninverted image. Link to post Share on other sites More sharing options...
cbretteville Posted October 16, 2006 Author Share #3 Â Posted October 16, 2006 Thanks Mark. Sounds like it will be a bit too restricting. I use 35 and 50s a lot and I wear glasses. Â - Carl Link to post Share on other sites More sharing options...
