biglouis Posted December 11, 2008 Share #1 Posted December 11, 2008 Advertisement (gone after registration) I purchased a s/h SAA 90/2 back in the summer and truth be told I have used it rarely. It is a lovely lens but it is very hard to focus on my M8. I have a megaperls 1.15 magnifier permanently fixed to my M8 eyepiece to help with focussing. Here is my question, or questions. Is the SAA 90/2 a particularly sharp lens, especially wide open? I've been using it for the last couple of days in very low light outdoor conditions and I would say that 90% of my captures are unacceptably sharp at 100% (whereas it is almost impossible for me to get an unsharp capture at 100% using my 24/2.8). I know you shouldn't really pixel peep and perhaps I need to be realistic but I am concerned that my pictures for a forthcoming Blurb book might also appear unsharp when printed, when using this lens. Secondly, should I be having problems with this lens wide open at infinity? Or should it be miraculously sharp at that setting? Again, wide open there is a feeling of softness. At less than infinity but say in the 30-50 foot range is focus super critical at f2. Again, pardon my naivity but I really do not use anything above 35mm very often. My main reason for using this lens is to capture building detail for 'cameo' pictures in my book. I doubt if any would be more than 7x5 inches on the page. Am I worrying too much about sharpness? TIA for any advice LouisB PS One thing I have deduced is that as it is such a heavy lens, I really should aim for 1/90 or above as a minimum speed when using this lens. Is this the case or should I be able to shoot down to 1/30 like I can with my smaller lenses? Link to post Share on other sites More sharing options...
Advertisement Posted December 11, 2008 Posted December 11, 2008 Hi biglouis, Take a look here 90 SAA/2 focussing issues. I'm sure you'll find what you were looking for!
Guest Lotw Posted December 11, 2008 Share #2 Posted December 11, 2008 I've had no problems at all focusing this lens, with or without magnifier: My most favourite lens when it comes to 'character', like selective focus, bokeh, etc etc. Send it back for adjusting! here are some examples, mostly at 2.0 or 2.5: http://www.l-camera-forum.com/leica-forum/other/65774-my-lovely-apo-90-a.html http://www.l-camera-forum.com/leica-forum/sonstiges/67090-reminiszenz-kert-sz.html http://www.l-camera-forum.com/leica-forum/other/62952-saturday-morning.html http://www.l-camera-forum.com/leica-forum/menschen/62533-jetzt-kenne-ich-dich.html http://www.l-camera-forum.com/leica-forum/sonstiges/61569-la-cena.html http://www.l-camera-forum.com/leica-forum/other/57943-summer-evening.html Link to post Share on other sites More sharing options...
biglouis Posted December 11, 2008 Author Share #3 Posted December 11, 2008 Lotw Thanks for the examples: stellar work. Somewhat embarassingly, I actually commented positively on the first example and enthused about how great a lens it was, so back in the summer I must have gotten some good results. Below is a capture from this morning, low light and shot at f2 iso1250. This is straight from the camera. It took maybe 4-5 shots to get an acceptably sharp one. When you say 'get it adjusted', can you explain what I would ask to have done? If it involves the camera as well I've heard that you can then introduce problems with other lenses which I clearly don't want to do. Thanks for your advice LouisB [ATTACH]116884[/ATTACH] Link to post Share on other sites More sharing options...
delander † Posted December 11, 2008 Share #4 Posted December 11, 2008 Hi Louis I have no problem focusing my 90 elmarit at f2.8, but I prefer to keep the shutter speed up over 180 for good sharpness. I would not be able to get many keepers at 1/30. Longer lenses are more demanding for accurate focus, the DOF is very low at f2. Is anything in focus or is everything soft? Jeff Link to post Share on other sites More sharing options...
Guest Lotw Posted December 11, 2008 Share #5 Posted December 11, 2008 Lotw Thanks for the examples: stellar work. Somewhat embarassingly, I actually commented positively on the first example and enthused about how great a lens it was, so back in the summer I must have gotten some good results. Below is a capture from this morning, low light and shot at f2 iso1250. This is straight from the camera. It took maybe 4-5 shots to get an acceptably sharp one. When you say 'get it adjusted', can you explain what I would ask to have done? If it involves the camera as well I've heard that you can then introduce problems with other lenses which I clearly don't want to do. Thanks for your advice LouisB [ATTACH]116884[/ATTACH] This seems to be slight movement unsharpness, I see no back- or frontfocus problems here. (I take it you focused on the A of commercial) But you're right; I've sent in my M8 with all my lenses , the 90 however was the only one that did not need adjusting Link to post Share on other sites More sharing options...
farnz Posted December 12, 2008 Share #6 Posted December 12, 2008 Louis, Sorry to hear you're having focussing problems with your 90 SAA; I use the HK 1.25 magnifier and, like Jeff, try to stay above 1/180. I was unimpressed with the results I was getting wide open, and at infinity the rangefinder patch and image didn't line up perfectly so I suspected that my VF needed some TLC. I upgraded the shutter and the VF was adjusted at the same time and now it's razor sharp. There's a tale in this RFF thread about a mis-focussing 90 SAA, where the OP had bought it second hand and had to send it to DAG for adjusment. Don ended up rebuilding the focus system because there was a degree of slop and the main culprit was the modern teflon grease; Don replaced it with the traditional Leitz grease and it focuses properly now. I guess you'll already know if your VF is spot on so it might help to to do a front/back focus test. I think the lens is superb when everything's lined up. Pete. Link to post Share on other sites More sharing options...
biglouis Posted December 12, 2008 Author Share #7 Posted December 12, 2008 Advertisement (gone after registration) You know, looking back at previous images I have some pin-sharp results taken in the summer in good strong sunlight. I think the problem here may be the explained by good old camera shake. I was working just after dawn both time I tried using the lens and even at iso1250 I was forced to use a relatively slow speed at f2 - even 1/30 vs 1/60. I think most of my work during the summer I was probably working a 1/4000! I need to do some testing with this lens to improve my technique and restore my confidence in using it. Thanks for the advice LouisB Link to post Share on other sites More sharing options...
