Oil on aperture blades
earleygallery
My 35mm Summicron R has traces of lubricant on the apterture blades. There was the slightest trace of some when I bought the lens s/h a few years ago but it's been working fine until the other day when I noticed that they aren't snapping back open as fast as they should.
I need to have the problem fixed. Any advice appreciated (if you've had a lens fixed with similar problems, cost, recommended repairers - I'm in the UK).
Thanks
James,
Might or might not help at this point, but always leave the aperture wide open on a Leica lens when you put it away. Had some oil on my 35/2 Type II and some other member suggested this. After a few months, no more oil. Worth a try.
If you have a mechanical problem, ask Malcolm Taylor.
DHL it to Solms for a CLA, Gerald Wagner is very helpful. I had my 14 year old pre-ASPH 35mm Summicron-M cleaned and it came back looking like new. About £160.
Mark,
CS is fine for the later stuff but they are too busy and too expensive for simple work on 30 - 60-year-old Leitz gear. The Leitz techs, Malcolm and over here, Sherry Krauter, can work on the old stuff blind-folded. In fact Solms sends their old gear to Malcolm for work...:)
My newer lenses, M7 and MP would go to Solms if they needed anything NJ couldn't handle, but my SL. old R-lenses and M5 would ONLY go to Sherry. The Leitz, Wetzlar-trained people just know this stuff cold. I presume James's 35/2-R is 70's-vintage. BTW, over here you can sometimes find a Mint 35/2-R two-cam for $350 - $400! :)
