Leitzmac Posted October 26, 2008 Share #1 Â Posted October 26, 2008 Advertisement (gone after registration) Hello everyone, Â Quick question: Â Do Leica make a rubber hood cap for the Elmarit 28mm (hood code is 12536)? I have one for my Summicron 35mm (hood code 12526, rubber cap code 14043) and when looking at the edge of the Elmarit hood I can see lips on the edge similar to those on the Summicron hood, but when I went into my local Leica dealer they said they'd never seen one. Â If anyone knows whether they exist (I'm presuming they must as Leica would hardly make a hood with lips if they didn't) please let me know where I might be able to find one. Â Many thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted October 26, 2008 Posted October 26, 2008 Hi Leitzmac, Take a look here Rubber hood cap for Hood No. 12536?. I'm sure you'll find what you were looking for!
ibogost Posted October 26, 2008 Share #2 Â Posted October 26, 2008 The two hoods are identical, as far as I know. I needed a replacement hood/cap for my Elmarit hood and bought the one advertised for the Summicron, and it works perfectly. Link to post Share on other sites More sharing options...
francofile Posted October 26, 2008 Share #3  Posted October 26, 2008 The hood cap (Leica part No: 14043) is available a a single item.  I got mine from Ffordes (ffordes photographic : Main Index) last year - the cost was around £16.00 including p&p.  I suggest that you buy a few - they are so easy to loose!!!!!  Good luck  Andrew Link to post Share on other sites More sharing options...
Leitzmac Posted October 27, 2008 Author Share #4 Â Posted October 27, 2008 Gentlemen, Thank you for your suggestions, however, as stated I have the 14043 cap already and it is too small. My feeling is that perhaps you have the latter Elmarits (mine is a variation of the third version) which may have smaller lens hoods? I am looking for a cap to fit a 12536 hood which is quite a bit larger than the 35mm Summicron hood. Â A little confused. Link to post Share on other sites More sharing options...
ibogost Posted October 27, 2008 Share #5 Â Posted October 27, 2008 Gentlemen, Thank you for your suggestions, however, as stated I have the 14043 cap already and it is too small. My feeling is that perhaps you have the latter Elmarits (mine is a variation of the third version) which may have smaller lens hoods? I am looking for a cap to fit a 12536 hood which is quite a bit larger than the 35mm Summicron hood. Â Aha, you are right. Sorry about that. Alas, I'm not sure I have any suggestions. My guess is that you'll have to chance upon the right cap somehow :-/ Link to post Share on other sites More sharing options...
palec Posted October 27, 2008 Share #6  Posted October 27, 2008 Gentlemen, Thank you for your suggestions, however, as stated I have the 14043 cap already and it is too small. My feeling is that perhaps you have the latter Elmarits (mine is a variation of the third version) which may have smaller lens hoods? I am looking for a cap to fit a 12536 hood which is quite a bit larger than the 35mm Summicron hood. A little confused.  Yes, that's right. Latest Elmarit 28 ASPH has identical hood and cap with Summicron 35 ASPH 12526/14043 which have smaller diameter - E39.  You can find hood codes here, but no caps: Home Page  However I' afraid that rubber hood caps are relatively new and never made for older hoods. Link to post Share on other sites More sharing options...
cbretteville Posted October 28, 2008 Share #7  Posted October 28, 2008 Advertisement (gone after registration) I'm not sure if there is a hood cap for the hood that fits the E49 28 Elmarit. I never found one for the one I owned. Backing this up is Puts' page with lens/hood/cap++ details. The slot for a hood cap for this particular lens is empty: List M lenses  Suggest you ask in the "collector's" forum someone is bound to have Lager a price list from the 80s when the lens was current.  Cheers, - Carl Link to post Share on other sites More sharing options...
Leitzmac Posted November 2, 2008 Author Share #8 Â Posted November 2, 2008 Thank you for all your suggestions chaps, I will try the 'Collectors & Historica' forum to see whether anyone there has any suggestions. Link to post Share on other sites More sharing options...
