| Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections |
Leica Products
Leica M » eBay | Adorama | B+H | Dale |
Leica M-E » eBay | Adorama | B+H | Dale |
Leica M Monochrom » eBay | Adorama | B+H | Dale |
Leica S » eBay | B+H | Dale |
LEICA D-LUX 6 » eBay | Adorama | B+H | Dale |
LEICA X2 Amazon | » eBay | Adorama | B+H | Dale |
#1 (permalink) |
Neuer Benutzer
When the hood on the tele-elmar 135 is reversed what lens cap goes on the hood?
Is it a special cap or is it a standard size? I found information on a cap for the lens when the hood is left in place which I understood was a 55 mm snap cap - is that information correct? |
#2 (permalink) |
Sponsoring Member
Ron,
The 12575 hood takes a 14033 cap. This is the same cap used for the 12585 hood used on 50 and 35 crons. It looks something like this from the back 14033.jpg - Carl Last edited by cbretteville; 30/09/08 at 00:19. |
#3 (permalink) |
Erfahrener Benutzer
If it's the hood I'm thinking of, same as the the one for the 90mm 12575N or some cryptic letter/number combo, with push bars on the side to retract the locking lugs it is a special cap of a special size that has cutouts to go around the push bars. Very hard to find when you want one. Fairly easy to find when you have no interest in it.
#4 (permalink) |
Erfahrener Benutzer
There is also a cap that mounts flush and locks in with the locking pins inside the hood.
If you are using a 39mm UV-ir filter, a modern Leica 39mm cap will fit with the hood reversed because the filter threads stick out far enough for the modern cap to engage into them. Last edited by robsteve; 30/09/08 at 00:55. |
#5 (permalink) | |
Sponsoring Member
Quote:
- Carl |
| Bookmarks |
| Current eBay Ads |
Current bid:
34.5 USD (0 bids)
Current bid:
21.5 USD (0 bids)
Current bid:
309.99 GBP (0 bids)
Current bid:
309.99 GBP (0 bids) |
| Thread Tools | |
| Display Modes | |
