captain Posted November 17, 2007 Share #1 Posted November 17, 2007 Advertisement (gone after registration) I have had a pair of Trinovid 10X25's for a couple of years since new. Green rubber armored that look nice and solidly made. Not a bad binocular overall. I just find the tiny focusing wheel really awkward. Its not rough to focus but nowhere near as silky smooth as the Compact Zeiss Classics I has before. In fact if there is no other sound around you can hear them focus! If you use two fingers to focus its a bit smoother but thats really awkward given their small size and when you use one finger to focus it must put downward pressure on the shaft and it gets a bit rougher to focus. They were meant to last a lifetime but they arent as nice to use as my Zeiss and Nikons that I have had previously. I notice that the Ultravids have a much larger focusing wheel. I was wondering if anyone upgraded to the Ultravids and if it was worth the change? Link to post Share on other sites More sharing options...
Advertisement Posted November 17, 2007 Posted November 17, 2007 Hi captain, Take a look here Worth Updating from Trinovid to Ultravid? . I'm sure you'll find what you were looking for!
andybarton Posted November 17, 2007 Share #2 Posted November 17, 2007 I have a pair of 10x42BN Trinovids and my wife has 10x32 Ultravids. The obvious difference is the size and weight, but the Ultras are nearly as bright as the Trinos. The focus ring on the Ultras is smooth, wide and chunky. Both pairs are a joy to use. Link to post Share on other sites More sharing options...
SoFi-Chaser Posted November 19, 2007 Share #3 Posted November 19, 2007 Since I could compare my 10x50 TrinovidBA against a Ultravid 10x42BL, I'm dreaming of an ultra (15x56 geo or another 2" now with the more resistant coating of the front lens). Even as a rather experienced observer, I was astonished about the difference in contrast and brightness. For smaller apertures as you might look for, the difference in handling should be more important. So just go into the shop and try out. If the ultra feels better, go for it and don't think of the price. Or don't do the test, because IF you like the ultra more than yours, you'll think of it, whenever you use your trino ;-) regards TS Link to post Share on other sites More sharing options...
wizard Posted November 19, 2007 Share #4 Posted November 19, 2007 I use a 8x20 Trinovid for 20 years now, and mine is a bit stiff to focus as well (always was). Recently, I compared a new 8x20 Trinovid to the then new on the market 8x20 Ultravid and noticed that even the new Trinovid focused much smoother than my own one. The Ultravid was even a bit better, but not much. Try a new Trinovid yourself to find out. Andy Link to post Share on other sites More sharing options...
yst Posted November 20, 2007 Share #5 Posted November 20, 2007 The overall quality of the new Ultravid pocket sized binoculars are BY FAR much better then the older models, the focusing is very smooth, the focusing wheel is bigger and taller, much easier to use; and the overall handling is better for sure as well. Those are the actual comparisons and field application experiences I have on those two models. Link to post Share on other sites More sharing options...
captain Posted November 20, 2007 Author Share #6 Posted November 20, 2007 Since I could compare my 10x50 TrinovidBA against a Ultravid 10x42BL, I'm dreaming of an ultra (15x56 geo or another 2" now with the more resistant coating of the front lens).Even as a rather experienced observer, I was astonished about the difference in contrast and brightness. For smaller apertures as you might look for, the difference in handling should be more important. So just go into the shop and try out. If the ultra feels better, go for it and don't think of the price. Or don't do the test, because IF you like the ultra more than yours, you'll think of it, whenever you use your trino ;-) regards TS Where I live in Australia there are basically no stockists of any Leica products its all mail order im afraid and no opportunity to sample them. So have to do alot of online research before committing. Link to post Share on other sites More sharing options...
Shac Posted November 24, 2007 Share #7 Posted November 24, 2007 Advertisement (gone after registration) If I understand your original question - you seem concerned with the focussing of your binocs. If you are happy with the optics - why not simply have them overhauled? David Link to post Share on other sites More sharing options...
leicapages Posted November 24, 2007 Share #8 Posted November 24, 2007 I am using the compact 8x20 Trinovid and the bigger 10x32 Ultravid. Apart from the obvious difference in terms of size/weight, I use them for different purposes. Both deliver excellent optical quality. I have compared the small Trinovid with similar compact glass from Minox and without any doubt the Trinovid are much better and more comfortable to use for eyeglass-wearers. Comparing the mechanical qualities of the Trinovid and the Ultravid, the latter is more sumptuous and overall smoother, including the focusing adjustment ring. If you buy new, get the Ultravid line. If you already have Trinovid, than it is uncertain whether you'd need upgrading at all. The best would be to try them out side by side. Link to post Share on other sites More sharing options...
stumac Posted November 24, 2007 Share #9 Posted November 24, 2007 James, Have you had a look at Bintel in Glebe, their melbourne shop had a good stock when I was in earlier in the year, they did a good job on an old Zeiss binocular of mine, clean and collimate. Regards, Stuart Link to post Share on other sites More sharing options...
