Leitz Leica Easel
click
Hello,
What sizes do Leitz easels come in? I'd be interested in a 16x12 version? Was this size made? I've seen 12x10 and 8x10 versions.
Yes, there was a rare Valoy intended for extreme enlargements. My 16x20 easel just fits properly. It an an extra long column, and a special cooling bonnet in the light housing to allow big watt bulbs. I have one. Never seen another.
What sizes do Leitz easels come in? I'd be interested in a 16x12 version? Was this size made? I've seen 12x10 and 8x10 versions. Click
The only one I have seen is 8x10, which I have. I like the locking feature. I also have a Saunders 11x14 border-less easel that is exactly the same thickness as the Leitz unit - which makes it usable with my autofocus Focomat Ic without further adjustments. The also make/made a 16x20 border-less unit
The larger easel I saw may indeed have been 12 x 16. In the US, the more common paper size is 11 x 14, so I may simply not have noticed the difference.
As you know, the Focomat Ic was delivered with a pin which fit into either of two different sets of holes in the upright. The lower set was for enlarging on the baseboard; the higher set was for use with the smaller Leitz easel.
The larger of the two easels was thicker, and was delivered with a spacing ring to be placed atop the pin when it was in the upper set of holes, to adjust the enlarger height to accommodate the easel.
I can't understand why the link you offer shows that the Ic was focused by helicoid. Yes, there was a helicoid for initial adjustment of the lens, but the autofocus mechanism was via cam, which extended the bellows.
Same with the Focomat V-35, where the link says the focusing type is unknown. Again, there's an adjustable helicoid to tune the lens and enlarger, but as an autofocus enlarger, its focus was cam-driven. No bellows in this case, but a collapsing tube mechanism.
The larger easel was really more suitable for use with the Focomat IIc, simply because of the size of the Ic's baseboard.
