Leica User Forum
Go Back   Leica User Forum > International User Forum > Customer Forum
Customer Forum The Leica Customer Forum is the place for discussions about the Leica in general, what is not covered by the more specialised sections
Your advantages as registered member:
  • Access to all sections and images
  • Posting own topics and postings
  • Access to the buy & sell section
Register here!
If you have any problems with the registration process or your account login, please contact us.
Old 12/20/06, 05:24 AM   #1 (permalink)
Benutzer
Frage Is a little wiggle normal on a 28-PC lens?
Just received a used 28 PC (perspective control) lens. There is a little wiggle space at the adjustment juncture, that is, the ability to rotate the lens just a little. The plane of rotation/wiggle is parallel to the film plane... but still.
Is a little bit of this normal?
Thanks.
Dean
Seattle, Washington
dritz is offline   Reply With Quote
Old 12/20/06, 10:20 AM   #2 (permalink)
Erfahrener Benutzer
masjah's Avatar
Default Re: Is a little wiggle normal on a 28-PC lens?
Dean
Mine is quite an early example (but has had a service at Solms recently). It has a very small amount of backlash parallel to the "normal" movement of the shift, but in practice this is of no importance in use, since gravity takes up the movement! Mine doesn't rotate though. I wouldn't worry too much provided that you are sure the slight play maintains the lens correctly parallel to the film plane.
The thing to be aware of is that, if you are using the maximum 11mm shift (as distinct from stopping at the 9.5mm detent position) you can go slightly out of the image circle in some extreme parts of the frame, and performance inevitably then falls off - so use the extreme with discretion - e.g. when the bit in question is just sky (or something of no significance in terms of detail). Actually you can see a fall-off at extremes even within the image circle if you look at Leica's published MTF graphs. Given what this lens is being asked to do though, it is an absolutely formidable design achievement. "Shifted" performance definitely requires the lens to be stopped down to f/8 or f/11 for very best results, so I usually use mine with a tripod. Best to focus before shifting is possible, and be aware of what they say about metering before making a maximum downward shift. Finally, don't forget to stop-down before metering and shooting - my most common mistake!!! Enjoy it - it's a revelation into the world of perspective!
__________________
Best wishes.
John
John Howarth
masjah is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why remove the internal slide-in hood on R lens? albertwang Customer Forum 3 09/10/06 12:15 PM
Does anyone know how to fit a diopter correcting lens on a Leica M2? colt1911 Customer Forum 25 08/08/06 11:54 PM
Little Eye, Hilbre (as seen on TV) andybarton Landscape & Travel 4 07/24/06 06:56 PM
Speculating re how M8 lens coding might work edlaurpic Digital Forum 45 07/19/06 12:10 AM
M8 Viewfinder Rolo Digital Forum 86 07/12/06 05:17 AM
