Guest mc_k Posted February 10, 2010 Share #1 Â Posted February 10, 2010 Advertisement (gone after registration) Hektor 28 apparently takes an 36mm push-on or 34mm screw-in. I would like to have a 34mm-to-39mm step-up ring made. Does the lens have the usual 34mm threading, or is there something special about it? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted February 10, 2010 Posted February 10, 2010 Hi Guest mc_k, Take a look here Attachments for Hektor 28mm. I'm sure you'll find what you were looking for!
doubice Posted February 10, 2010 Share #2  Posted February 10, 2010 Hektor 28 apparently takes an 36mm push-on or 34mm screw-in. I would like to have a 34mm-to-39mm step-up ring made. Does the lens have the usual 34mm threading, or is there something special about it? Thanks  My recommendation would be to look for a SOOGZ / 13154 adapter. It will clamp onto A36 mounts and will accept E39 filters.  Best,  Jan Link to post Share on other sites More sharing options...
Guest mc_k Posted February 10, 2010 Share #3 Â Posted February 10, 2010 thanks, I would still prefer to use the threading...it's easy enough to have an adapter ring made. Link to post Share on other sites More sharing options...
doubice Posted February 10, 2010 Share #4 Â Posted February 10, 2010 As per my B+W 'Filter Reference Bible' published for dealer use during the 1970's, Leitz used 34 thread with x 0.5mm pitch (34 x 0.5mm). However - word of caution: the refence book lists all A36 lenses that accept 34mm filters (Summar 2/50, Elmar 4/90mm, old Hektor 4.5/135mm) but, next to the listing for the 28mm Hektor it only lists the A36 filter mount. The 34mm thread option is not mentioned, as it is with the above lenses. Â I did check my 28mm Hektor however, and it indeed has a thread that may well be 34mm. Â Best, Â Jan Link to post Share on other sites More sharing options...
Guest mc_k Posted February 10, 2010 Share #5 Â Posted February 10, 2010 Thank you Jan, that was exactly the info I needed. I will give it a try. Link to post Share on other sites More sharing options...
tobey bilek Posted February 11, 2010 Share #6 Â Posted February 11, 2010 SKGrimes.com Link to post Share on other sites More sharing options...
Guest mc_k Posted February 12, 2010 Share #7 Â Posted February 12, 2010 Advertisement (gone after registration) thanks...I can also recommend them from past work. Link to post Share on other sites More sharing options...
