Play in apperture ring
shootinglulu
Guest finofoto
hello,
this is (unfortunately) normal with Leica (M)lenses: the aperture gear-ring is hold with a spring - quite flexible and different for each lens... and this causes the wobbling. (so a mechanic declared this issue to me and explained, that he could not "repair" it).
even with my sx 21 i have this phenomen,
hope it helps,tom
Hallo.
I bought my 28 cron, new, a month or so ago and it has slight play in the apperture ring at f2, just a mill or so, i wonder if this is usual and ok?
Thanks, Lucy
A millimetre or so???
There is a detent each half stop and you can pop the ring just out of that detent on mine (nominally past f/2). Can you look in to confirm that there is no diaphragm movement when you move the ring past f/2? If so (and I expect that to be the case) then there is no functional problem or error in operation at all. I just checked every other Leica M lens I have (all modern) including two that Solms have just adjusted to perfection for my M8 and you can pop the aperture adjustment ring just out of the detent in that direction in every case.
I don't know where you are Lucy but you could certainly ask Solms for advice if you are concerned. My take is that you have no problem at all and one of the best lenses on the planet. Enjoy.
I had a wobbly aperture ring on a new Mk IV 35mm Summicron M - sent it to Milton Keynes and they remedied it. But before sending it I got a second opinion from another Leica dealer that it was in fact outside normal tolerance.
Cheers
dunk
Send it off to Solms. When it comes back it will be so loose and floppy a strong breeze will shift it for you.
'Normal tolerance' ...................... :D ................... :D:D:
The fact that the looseness was remedied suggests that when newly purchased the play in my lens' aperture ring was outside 'normal tolerance'. If you find that :D would you please justify your remark.
dunk
