Scott Root Posted November 24, 2006 Share #21 Posted November 24, 2006 Advertisement (gone after registration) What's the advantages of the second version over the first version? Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2006 Posted November 24, 2006 Hi Scott Root, Take a look here Should I get a tri-elmar for my M8?. I'm sure you'll find what you were looking for!
Peter41951 Posted November 24, 2006 Share #22 Posted November 24, 2006 Depth of field scales. Link to post Share on other sites More sharing options...
blovitch Posted November 24, 2006 Share #23 Posted November 24, 2006 And better frame selection.... (except on an M8) Link to post Share on other sites More sharing options...
harmsr Posted November 24, 2006 Share #24 Posted November 24, 2006 The second version has a smaller filter size. It uses a 49mm filter. However, you must also use a snap on hood, where if I remember correctly the first version had the hood built in. The second version was designed for more positive engagement of the focal length changing ring. Optically, they are purported to be the same. The 49mm filter size works out very convenient for me as the 75 cron is also a 49mm filter. Best, Ray Link to post Share on other sites More sharing options...
danielt Posted November 24, 2006 Share #25 Posted November 24, 2006 Scott, Check this: http://www.leica-camera-user.com/digital-forum/8761-tri-elmar-generations.html Link to post Share on other sites More sharing options...
