brunom Posted November 24, 2006 Share #81 Posted November 24, 2006 Advertisement (gone after registration) Sean, Adan From memory the 15 mm C/V lens does not have a filter thread, but the 12mmm does which of course will allow it to be used with an IR filter if needed. Bruno Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2006 Posted November 24, 2006 Hi brunom, Take a look here NEW info from my dealer!!!. I'm sure you'll find what you were looking for!
Mark D Posted November 24, 2006 Share #82 Posted November 24, 2006 Sean, Adan From memory the 15 mm C/V lens does not have a filter thread, but the 12mmm does which of course will allow it to be used with an IR filter if needed. Bruno From the Cameraquest site: You can use filters, but only if they are much larger than the lens, such as gelatin filters and say, 72mm filters. Play a around with it, whatever works, works. You will have to tape it, or more likely, hold the filter in front of the lens during the exposure. Another option is using the 12's 77mm filter adapter. The 15's barrel is a bit smaller, wrapping some electricians tape around the lens barrel will allow you to mount the clamp on 12's 77mm filter ring. Link to post Share on other sites More sharing options...
