Anyone using a cleaning solvent or kit to cleanr print heads?
The first link is the one I bought. Got it this morning and I've used the kit. It say's to let the printer sit for 6-8 hours before running a clean cycle and nossle check, so I'll know this evening and post whether it worked or not.
It does not mention the R2400 on the ebay listing, but I think it will work. Check with the seller. Pretty simple to do. Shipping was fast and I have high hopes for success.
Print head cleaner cleaning Epson 1280 R800 R1800 2200 - eBay (item 380156023522 end time Oct-05-09 14:42:25 PDT)
Second link is for instructions. There is also a link on the Listing for instructions.
photo-i • View topic - How to unclog print heads for Epson R2400 R1800 2200/2100
For $7 it was worth a shot for me. I was quoted $125 and up for repair and if this does not work, I'll just get a new printer as this has done well.
Hope this helps.
Randy, I ordered something called "Epson Stylus Head Cleaning Solution" from fixyourownprinter.com, today. It is supposely the same solution that Epson uses in their repair department.
I'll post some results after I use it, too.
After doing everything that was suggested and using the cleaning kit, I still only have about 95% of the nozzle check for magenta printing. I printed a page with just magenta and there was no banding and printed a test print and it looked fine. I'm now at a loss for what to do next.
Ok, dumb question, Bill...the automatic print cleaning utility cycle didn't work?
Jeff
None of the admin functions will work. The printer sends a dont-talk-to-me signal. No cleaning, no nothing.
Waiting for the stuff to arrive.
Hot damn! I am watching a print come out of my printer!
It's very frustrating when a head is clogged because none of the admin functions will work. Not the clean, not the print test, nothing.
I bot Epson Stylus Head Cleaning Solution from fixyourownprinter.com for $9.95 plus $3.50 shipping.
An application following the directions and a couple of overnights (I was a little busy to check until now), and the print test and cleaning cycles worked fine. The print test was excellent.
The print JUST came out and looks fantastic!
Regards to all,
Randy, sorry yours didn't work as well.
This printer sat all summer (the fault of my stupid assistant!) and I applied enuf solution to thoroughly soak the 2 pads in my 2400. It sat at least 24 hours. I think I will run head checks periodically in the future rather than let it sit idle.
Works great, now.
G'luck.
