shoreline Posted September 20, 2009 Share #1 Posted September 20, 2009 Advertisement (gone after registration) The outside is 24mm , what size is the inside framing? Link to post Share on other sites More sharing options...
Advertisement Posted September 20, 2009 Posted September 20, 2009 Hi shoreline, Take a look here D-Lux 4 accessory bright viewfinder 2 sets of framing?? . I'm sure you'll find what you were looking for!
jimbo035 Posted September 20, 2009 Share #2 Posted September 20, 2009 The outside is 24mm , what size is the inside framing? 35mm. as to setting the 35mm focal length, some time ago I posted the following in another thread, viz "D-Lux 4 Viewfinder -what are you using ?" ... a little experiment using EXIF data and a series of pictures taken at different zoom extensions which compared the location of the white zoom indicator bar to the: "1.64ft - 00(inf)" shown in the LCD while zooming. (The experimenter) used "P" mode and the digital zoom was turned off. Here are the results. If you set the white bar all the way to the left you (obviously) get 24mm. Under the "1" = 26mm. Under the "." = 28mm. Under the "6" = 32mm. Under the "4" = 37mm. Under the "f" = 41mm. Under the "t" 44mm. Under the "first empty space" = 48mm. Under the "hyphen" = 52mm. Under (actually a little to the left of) the "left infinity loop" = 57mm. And finally all the way to the right (again obviously) 60mm. Link to post Share on other sites More sharing options...
shoreline Posted September 20, 2009 Author Share #3 Posted September 20, 2009 thank you , I am ordering the x-1 and was thinking of keeping the Dlux 4 viewfinder to use on it. Any comments? Link to post Share on other sites More sharing options...
