Dual Range Summicron doesn't fit M9?
M. Valdemar
They said the M8 couldn't use the DR Summicron, but most of them worked fine. Ditto for the Epson R-D1, the manual said no but mine worked perfectly.
Are they just talking about the close-focus function, or is there some odd reason the DR 50mm Summicron can't mount or focus on the M9 as a normal lens without the closeup attachment?
On the RD-1, the close-focus part of the range wouldn't work, but the lens worked fine
On the M8, the close-focus half of the RF cam at the back of the DR would bind on something inside the camera, and you couldn't focus it in the normal range.. If you had the close-focus portion of the cam machined off, the lens worked fine. I had this done on my DR.
I suspect the M9 has a similar issue, but I don't know this for a fact.
