Don'tknowmuch Posted September 4, 2009 Share #1 Posted September 4, 2009 Advertisement (gone after registration) Just a quickie; Neopan in DD-X? What film speed/DD-X times? I've seen the Massive Dev Chart on this combination at 250asa and 400 asa so can just have a go, but thought there is probably some good advice to be had here. If little or no penalty for going with box-speed I'd be keen to work at 400. If there is a penalty then a lower asa may be the way to go. Thanks all, Jim. Link to post Share on other sites More sharing options...
Advertisement Posted September 4, 2009 Posted September 4, 2009 Hi Don'tknowmuch, Take a look here Neopan 400 in Ilfotec DD-X . I'm sure you'll find what you were looking for!
batmobile Posted September 4, 2009 Share #2 Posted September 4, 2009 I would rate at 400 or so in average British light, at 500 if flat as a pancake and as low as 250 if using area metering and there is a very high contrast range. I typically rate it at 320 in sunny, contrasty conditions (outside the UK ) As for times, I can give you mine which are for printing on a diffuser enlarger and to get a full tonal range. For a condenser or scanning these would be too high: DDX 1+7 (I dont use 1+4) 23 degs C 9.5 mins. 20 secs agitation initially, then 3 good inversions per minute. This is not a million miles away from the Ilford time for 1+4, 24 degs, 5 mins. I tend to find Ilford times (with some exceptions) result ina neg that is a little thin for my soft enlarger. You could try 23 degs, 1+7 and 8-8.5 mins if you want a lower contrast neg. Link to post Share on other sites More sharing options...
Don'tknowmuch Posted September 5, 2009 Author Share #3 Posted September 5, 2009 Thanks for this. A lot of information in a concise post. I'll see what the weather's doing before I head out! Jim. Link to post Share on other sites More sharing options...
