Fill-flash with Leica SF 58
fackel
I recently bought an SF 58 mainly to use it for fill-flash with my M8.2 in certain situations (portraits, back-lit subjects and the like). Unfortunatelly the SF 58 behaves in a different - and in my opinion not at all satisfactory - way than I was used previously from my Canon 580 EX. I was expecting to get equally exposed images no matter what aperture or ISO setting the camera would be set (of course in the limits of the unit's possibilities). As my expectations where not met in "real-life" pictures, I did the following comparative test with both systems: both flash guns in (E)TTL mode, cameras in A mode (aperture priority), "neutral" target (ColorChecker and a Kodak grey card in the center of the frame) at about 1.5m distance from the camera:
M8, Summilux 50 ASPH, and SF 58 in TTL mode:
f/1.4, ISO 160: image heavily overexposed
f/2.8, ISO 320: image overexposed
f/5.6, ISO 320: image (almost, i.e. a little on the darker side) properly exposed
f/8.0, ISO 640: image a tiny bit darker than at f/5.6
Canon 20D, EF 50/1.4, 580 EX II in ETTL mode: all images at same apertures (1.4 up to 8.0) and comparable ISO settings (200, 400, 800) properly and all four equally exposed (a bit lighter, in my eyes "better", than the M8/SF58 results at f/5.6 and f/8.0).
The flash had its visit at Leica in Solms but came back unmodified. The verdict: flash works as designed, overexposure is due to the too short distance the images where taken from?!
Hope anybody can shed some light on this topic.
Franz
Franz, here is an idea how you can find out whether Leica's statement is correct: Recreate your setup so that you get overexposed pictures in ETTL mode. Then set the flash to manual, adjust its power setting to the minimum (1/256) and take another picture (without changing ISO or aperture). If you still get an overexposed picture Leica is right because the flash can't emit less light.
Please report back with your findings.
Die Nachricht war eigentlich für das internationale M8-Forum gedacht - wollte die Jungs und Mädels dort von ihren M9-Träumen ablenken.
Tschuldigung. Ich dachte, es sei eine ernst gemeinte Frage. :o
Ne, ne, die Frage war schon ernst gemeint, sie hat sich aber - wohl aufgrund meines Fehlers in der Bedienung der Forums-Knöppsche - trotzdem in das deutsche Forum "verirrt". Ich nehme also gerne jeden Tipp (sei er in Deutsch oder Englisch) dankbar an.
Sorry, dass ich auf Deine Antwort nichts erwiedert hatte - es war mir aber irgendwie peinlich, das Posting im "falschen" Forum fortzusetzen. Jetzt tu ich es aber doch :) Nun, ich habe die Kamera leider zurzeit nicht greifbar (sie ist wegen eines falsch fokusierenden Summilux 21 in Solms). Deine Idee mit der manuellen Einstellung fand ich aber sehr einleuchtend. Ich hab mir darauf hin die beiden Blitzgeräte angeschaut: Das Leica Gerät lässt sich, wie Du es gesagt hattest, auf 1/256 seiner Leistung herunterregeln - und jetzt kommt das Witzige: Das Canon-Gerät, das meinem Test "erfolgreich" bewältigt hat, lässt sich nur auf 1/128 herunterregeln, müsste also in seiner minimalen Einstellung heller als das Leica-Gerät sein - wir erinnern uns aber: Der Leica-Blitz hat überbelichtet und nicht der von Canon. Für die definitive Beurteilung heißt es also abwarten, bis meine M8 wieder Heim kommt.
Danke.
