docmark Posted September 1, 2009 Share #1 Posted September 1, 2009 Advertisement (gone after registration) Which viewfinder do I need to purchase for a 24mm Summilux lens, to use on my M8? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted September 1, 2009 Posted September 1, 2009 Hi docmark, Take a look here Brightline viewfinder. I'm sure you'll find what you were looking for!
Guest WPalank Posted September 1, 2009 Share #2 Posted September 1, 2009 You don't have to. The bright-line frames for the 24 will automatically appear (along with the 35 frames) once the lens is attached. Link to post Share on other sites More sharing options...
hoppyman Posted September 1, 2009 Share #3 Posted September 1, 2009 Which viewfinder do I need to purchase for a 24mm Summilux lens, to use on my M8? Thanks. The 24 mm frame-lines are provided in the M8 finder, however you can choose to use an external one of course. The new Leica 24 external finder contains frame lines for a 24x36 camera as well as a set of crop marks that apply for the M8. It does cost a lot however! The Zeiss and Cosina 25 finders will not work for you. They will work if you are using film or a 24x36 sensor (!), however. You would need one made for 32mm on film, approximately for a 24mm on the M8.. Link to post Share on other sites More sharing options...
