lars_bergquist Posted August 31, 2009 Share #21 Posted August 31, 2009 Advertisement (gone after registration) 2. Coding is needed to correct vignetting, not the IR issue, which can be set through the camera menu and does not require coding (as long as you have a UV/IR filter on, of course) ... Coding is necessary to activate in-camera correction of the cyan shift that a UV/IR filter causes off axis, and which becomes noticeable at focal lengths above 35mm on the M8, and above 28mm with a full-frame camera (I just checked the last statement). It does also correct ordinary luminance vignetting, but that is a different phenomenon entirely. The old man from the Age of the Yellow Filter Link to post Share on other sites More sharing options...
Advertisement Posted August 31, 2009 Posted August 31, 2009 Hi lars_bergquist, Take a look here Ideal start up pairing. I'm sure you'll find what you were looking for!
lxlim Posted August 31, 2009 Share #22 Posted August 31, 2009 Coding is necessary to activate in-camera correction of the cyan shift that a UV/IR filter causes off axis, and which becomes noticeable at focal lengths above 35mm on the M8, and above 28mm with a full-frame camera (I just checked the last statement). It does also correct ordinary luminance vignetting, but that is a different phenomenon entirely. The old man from the Age of the Yellow Filter Thanks, Lars. Your explanation is better than I can manage. Link to post Share on other sites More sharing options...
Ecar Posted August 31, 2009 Share #23 Posted August 31, 2009 Coding is necessary to activate in-camera correction of the cyan shift that a UV/IR filter causes off axis, and which becomes noticeable at focal lengths above 35mm on the M8, and above 28mm with a full-frame camera (I just checked the last statement). It does also correct ordinary luminance vignetting, but that is a different phenomenon entirely. The old man from the Age of the Yellow Filter It seems I stand corrected. Always thought it was the same nature of correction. Guess this is because I never bothered to check the difference... Thank you gentlemen - there's always something to learn in this forum! Link to post Share on other sites More sharing options...
lxlim Posted August 31, 2009 Share #24 Posted August 31, 2009 It seems I stand corrected. Always thought it was the same nature of correction. Guess this is because I never bothered to check the difference...Thank you gentlemen - there's always something to learn in this forum! Its a great forum. Link to post Share on other sites More sharing options...
