M6 TTL battery
wbesz
What battery voltage is used in the M6? It seems my M6 is the TTL version (not the classic. Are the batteries different:confused: between these two cameras?The classic seems to use smaller batteries.
THank you in advance. William
The same batteries can be used for the M6 classic. Personally I prefer the lithium batteries (1/3N). One has to live with a hidden disadvantage - they last so long, one probably has forgotten the battery type, when they are finally flat....
I bought two 1/3N batteries, when I bought the camera, the second one has a shelf life until 2017, according to the package...
A manual for the M6 classic can be found here:
Leica Bruger Information: Leica M6 Classic Manual
Stefan
Stefan
Stefan, what about M6 TTL?
Thanks
Thanks guys, but those small batteries only add up to be 3 V (for the M6 classic), I thought perhaps the M6TTL version used more voltage (bigger) cells and would add to be 6volts?
CR 1/3N is the full name of the battery. The M7 uses two, all M6s use one. They're quite expensive retail, like at Radio Shack. Get them on the internet, best battery is probably Varta, best value is bulk Sanyo. Shelf life is enormous.
