microview Posted August 18, 2009 Share #1 Posted August 18, 2009 Advertisement (gone after registration) Recently I acquired a mint Zeiss 35 f2 Biogon, which proved to be a superb lens (as Erwin Puts noted at the time it was released). Indeed, I prefer it the two samples of the 35mm Summicron ASPH which I have owned. The one thing missing was a front lens cap and, as many will know, a Zeiss replacement is hard to find. Instead I ordered a 43mm Voigtlander which, like the Zeiss, push fits inside even when a hood is in position. However, the lens rim isn't sufficiently deep for the cap to hold in place. It does, though, fit neatly into a B+W uv/ir filter (Leica doesn't offer the 43mm size). Problem solved! And maybe a help to somebody reading this... Incidentally, the projection to the front of the Zeiss hood is a substantial 65mm but the balance of this lens is extremely comfortable on the M8. Link to post Share on other sites More sharing options...
Advertisement Posted August 18, 2009 Posted August 18, 2009 Hi microview, Take a look here zeiss lens cap info. I'm sure you'll find what you were looking for!
