R lens distance scale?
masjah
The focus distance on a lens is defined as the sum of the object and image distance, so from the sensor/negative to the object.
Via the lens equation which is good enough for this purpose 1/f = 1/O + 1/B and the focus on the lens scale is O + B. (O = Object, B= Bild = Image, f = focal length)
Stephen
Many thanks for the clarification. So I'll simply measure tot the film plane ( O + B).
Focus is measured from the film plane. On some R-cameras, there is a mark on the top plate, consisting of a small circle with a line through the middle. That indicates the film plane. On earlier Leicaflexes (and R8/9), just judge by the rear edge of the shoe.
Thanks ismon - since I have an R8 abd an R9, that was my next question.
