Leica Lens Question
minks73
I have noticed that a on lens that I have recently bought second hand - the focus dial would actually turn to a point approx. 7mm past the line on which minimum distance required to focus is marked. (i.e. this summilux lens has 1m mark as the minimum distance required to focus which the lens focus dial would turn past by a good 7mm. Shouldn't the focus dial stop at or at least very close to the maximum/minimum focus distance marks? Your help is much appreciated.
If the infinity mark lines up with the focusing index line, there is nothing wrong with the lens. All Leica lenses turn slightly past the minimum focus mark, be it 1m or 0.7m.
Use the lens and enjoy it......
Best,
Jan
Best,
Jan
Some long lenses are designed also to focus past infinity (I believe to allow for expansion with a large lens), but, as Jan implies, putting the infinity sign against the focus index line always sets the focus to infinity.
That is correct; my 4.8/280mm Telyt-V is designed like that and it is indeed to allow for thermal expansion. Focusing was done on the screen of the Visoflex so, when the focused image was sharp in the Viso's finder, it was sharp on the film (sensor) plane too - no matter where the distance scale was in relation to the focus index.
I believe however, that the OP's lens was not one designed for the Visoflex. Also, his 'beef' was that the focusing ring moved past the indicated minimum focus distance. This is normal on all lenses, whether ones designed for the Visoflex, or not.
Best,
Jan
