snaggs Posted June 6, 2009 Share #1 Posted June 6, 2009 Advertisement (gone after registration) I was just reading that the M7 can do HSS with the right flash. If not MP, then for M7, what flash can I use and how well does it work? Daniel. Link to post Share on other sites More sharing options...
Advertisement Posted June 6, 2009 Posted June 6, 2009 Hi snaggs, Take a look here Can MP do HSS with any flash? Which flash?. I'm sure you'll find what you were looking for!
russell c. greenberg Posted June 6, 2009 Share #2 Posted June 6, 2009 I was just reading that the M7 can do HSS with the right flash. If not MP, then for M7, what flash can I use and how well does it work? Daniel. Daniel, The MP is not capable of HSS, only the M7 is. You need a Metz 54 series flash with a SCA3502(M5 or higher) module. You set this flash to manual,turn the wheel on the right side (rear panel facing you) until HSS appears on the display. You can then take flash photos at 1/250, 1/500 or 1/1000. Hopes this helps. Russell Link to post Share on other sites More sharing options...
Steve Ash Posted June 6, 2009 Share #3 Posted June 6, 2009 That is the main reason why I went for an M7 as a complement to my M8.2. Regards Steve Link to post Share on other sites More sharing options...
