Voigtlander 28mm f2 and M6
dcuthbert
Are you sure the lens is properly locked in place? AFAIK, the 28/90 flange prong to trigger the frame lines is the longest of the three options. If the lens isn't twisted in completely, it could potentially activate the wrong frame lines, I'm afraid. The order to the best of my knowledge is: 28/90 -> 50/75 -> 35/135
Regards
Ivo
Brings up the correct framelines on both my M8's. Those are the only M's I have that have 28mm framelines.
I suspect you have not locked it in all the way. It should move the lever all the way to the right (closest to the lens).
