Soft Release for Barnacks
When I bought my Leica IIIa in 1952, it had a soft release installed that seemed very desirable for the camera. It was not until later that I realized that all Leicas were not made this way.
Does anyone know the origin of this device? Was it made by Leitz, or someone else?
It now resides on my Leica IIIf RD.
x
Definitely not of Russian origins. These soft releases were quite common during the 1950's and were mostly made in Japan. Many Japanese Leica copies used the same thread around the shutter release collar and the releases could be used on all of them.
I still have a couple of them burried somewhere among my old Leica paraphernalia.
Best,
Jan
Thanks, Jan. That makes sense to me. I like this release because it keeps my finger from dragging the shutter speed knob, and also provides a better control of the shutter release.
Jim N.
Actually, this LEITZ device it´s the opposite of a softrelease, because you had to
touch the releasebutton within the mould to trigger the camera.
The device made sure, your camera was´t fired unintentionally too often.
The mushroombutton on the early LEICA I was the prototype of the softreleases.
O. B. had done it already in the very early days ...
Best
You are correct that it is a great improvement in preventing unintentional operation of the shutter. Are you indicating that they were actually made by Leitz?
Jim N.
Jim,
This accessory was never produced by Leitz. As I mentioned in my first post, it was made in Japan as were many LTM accessories during the 1950's.
It is actually quite well thought out - it is spring-loaded to provide extra resistance when tripping. As mentioned before, the outer collar also prevents accidental shutter release. Also, one can rest a part of one's finger on its edge, while applying pressure against the release - this results in better balance and smoother release.
Best,
Jan
Sorry that I created such a furor. I conclude that this useful device was made in Japan, not by Leitz, and would only be of interest to the users of old Leicas, such as myself. My thanks to everyone for putting this question to rest.
Jim N.
  • 2 weeks later...
Looks like a 1949 SOREI, from E.Leitz (NY). Some are engraved, some not. Might also be an aftermarket copy.
Since my IIIa had been fitted with a flash-synchronized baseplate and flash unit by E.Leitz (NY), it is quite likely that is the source of the added release. I can find no engraving on it.
Thanks,
Jim N.
