Leica M3 bayonet defect?
gonzo
Hard to tell from the pics but it looks to me like the small lug at the bottom is bent? ...
Could also be the spring behind the mount proper, which is supposed to hold the lens against the body. But if it gets out of place, it could catch the lens and prevent its turning.
This has been an interesting thread but we haven't solved your problem, gonzo. :o Be glad you weren't paying for our advice! :p
Let us know how the matter progresses!
<<How that could've possibly happened I don't know.>>
gonzo, the dent on the lens's mount ring has got to be milled out 1/100 mm deeper and it just works fine.
BTW, I didn't intend to brag about Swiss service. It was ment just as a report of things that happened. Leica M's are marvellous cameras but they need constant service and repair. I know that only from Hasselblad's also. But the care is rewarded with the best 35mm photographs you've ever seen :)
Hi Howard, I imagine that it wouldn't be possible to somehow test that it is the spring behind the mount is faulty is there? All the advice has been great! I've sure learned a lot alone the way :-)
I have no problem in investing in a great camera, just wish the the seller had been up front about the damage...
