DrJohnGreg Posted February 17, 2009 Share #1 Posted February 17, 2009 Advertisement (gone after registration) I have 2 of these projectors, recently purchased. I want to connect them together to use their internal lap-dissolve system. For this I need the cable called the 'Lap-Dissolve Cable part no. 37 375. I can't find this anywhere and wondered about making one up as I have some of the 8 pin mini DIN plugs. Does anyone know where I can get the correct wiring diagram for this cable? Link to post Share on other sites More sharing options...
Advertisement Posted February 17, 2009 Posted February 17, 2009 Hi DrJohnGreg, Take a look here Pradovit RT-m advice . I'm sure you'll find what you were looking for!
Doc Henry Posted February 17, 2009 Share #2 Posted February 17, 2009 Hi Doc John, I have also a Pradovit but only one not two like you, so i don't need the cable. but i have found this note with the connector socket diagram.. Is it what you are looking for ? . Link to post Share on other sites More sharing options...
DrJohnGreg Posted February 18, 2009 Author Share #3 Posted February 18, 2009 Thanks for this advice, I will start poking about and see what happens. Link to post Share on other sites More sharing options...
yst Posted February 24, 2009 Share #4 Posted February 24, 2009 Hi Dr. John Greg, have you found that cable yet? If not, would you like to contact me? I have the new ones. I have 2 of these projectors, recently purchased. I want to connect them together to use their internal lap-dissolve system. For this I need the cable called the 'Lap-Dissolve Cable part no. 37 375. I can't find this anywhere and wondered about making one up as I have some of the 8 pin mini DIN plugs. Does anyone know where I can get the correct wiring diagram for this cable? Link to post Share on other sites More sharing options...
