GMB Posted January 31, 2009 Share #1 Posted January 31, 2009 Advertisement (gone after registration) I recently updated from version 4.0 to version 4.6. Since then the following problem occurs. When starting C1, the program first works fine. However, after I played with a few shots for a while, the picture in the large preview behaves (1) is not sharp when switching to a new shot (i.e., you see pixels even though it is at, say, 50%) and and (2) does not show any modifications I make (such as white balance, exposure etc.) The weird part is that when I go with the cursor into the preview picture and enlarge the picture to, say, 66%, it becomes sharp (no pixels) and shows the changes. But when I then make additional changes, they only show when I change the size again. At the same time the problem with the preview picture occurs, the histogram no longer updates to reflect the changes I made. There is no way I can make it show the changes. If I then close and reopen C1, it will work fine for a couple of shots before showing the same symptoms again. You can imagine that this drives me nuts and that I would be most grateful for any advise. FYI, I am running this on a less than 1 year old Power Mac with 6G RAM and I still have plenty of disc space. Thanks for any comments. Georg Link to post Share on other sites More sharing options...
Advertisement Posted January 31, 2009 Posted January 31, 2009 Hi GMB, Take a look here Problem with C1 after udate to version 4.6 . I'm sure you'll find what you were looking for!
GMB Posted February 2, 2009 Author Share #2 Posted February 2, 2009 Just in caes others encounter the same problem. I uninstalled C1 and reinstalled it and the problem seems to be solved. Link to post Share on other sites More sharing options...
ho_co Posted February 3, 2009 Share #3 Posted February 3, 2009 Thanks for the word, Georg! Good that you alerted us to the possible problem and even better that you gave us the solution. And I'm glad the fix was that simple. Link to post Share on other sites More sharing options...
