Bounce Flash
Annibale G.
I use a Metz 54i with a couple of different cameras, normally in Auto (A) mode. Works very well w/o correction, usually. Theoretically TTL should work the best, I just hate the pre-flash it fires, when set to TTL operation.
If you use the M mode, you'd either have to calculate / estimate the proper aperture, or, even better, measure it with an external flash meter.
Regards
Ivo
