Lightroom Beta 4 impressions
biglouis
Does Capture One allows for sidecar files which include the changes made to the RAW like Lightroom and Aperture?
Hi Ruben,
C1 keeps track of the settings used for a given file so if you make adjustments and re-open the same file later, your previous settings will be the default for that file.
Cheers,
Sean
Thank you Sean.
In that case, you can avoid to save a big TIFF fije from the RAW processed file, isn't? You can select the parameters and record then into the side car file. This saves a lot of space. Only if you need heavy work in Photoshop you will end with another file.
