misha Posted December 9, 2008 Share #1 Posted December 9, 2008 Advertisement (gone after registration) very very different, to say the least ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/70834-orion-15-28mm-f6/?do=findComment&comment=741103'>More sharing options...
Advertisement Posted December 9, 2008 Posted December 9, 2008 Hi misha, Take a look here Orion-15 28mm F6. I'm sure you'll find what you were looking for!
M. Valdemar Posted December 9, 2008 Share #2 Posted December 9, 2008 The lens is much sharper than that. You might have a fogged or damaged example. Link to post Share on other sites More sharing options...
misha Posted December 9, 2008 Author Share #3 Posted December 9, 2008 The lens is much sharper than that. You might have a fogged or damaged example. you are right, and it is. that said, it wasnt sharpness that i wanted to emphasize here, but a completely different feel to photographs taken with this lens. Link to post Share on other sites More sharing options...
razerx Posted December 9, 2008 Share #4 Posted December 9, 2008 I have a coded adapter to use it with the M8. It is a very sharp lens even wide open. Has anyone used the Hektor 28mm F6.8 enough to comment on its performance? Link to post Share on other sites More sharing options...
misha Posted December 9, 2008 Author Share #5 Posted December 9, 2008 I have a coded adapter to use it with the M8. It is a very sharp lens even wide open. Has anyone used the Hektor 28mm F6.8 enough to comment on its performance? were you able to put a UV/IR filter on? 39mm fits perfectly but doesnt hold. Link to post Share on other sites More sharing options...
razerx Posted December 9, 2008 Share #6 Posted December 9, 2008 were you able to put a UV/IR filter on? 39mm fits perfectly but doesnt hold. No I couldn't put a uv/ir filter on it. I mostly convert the files to b/w anyway so didn't worry about it. Link to post Share on other sites More sharing options...
