M Summaron 3.5 goggles
LeonardT
Does anyone know why the goggles on the M Summaron 3.5 are removable? With them attached it brings up the correct 50mm frame lines and 35mm field on every M body I've tried which is the M2, M3, M6 and M8. Ser# 1595xxx. I'm just curious. I picked up the lens today. It's mint and has the original box and fitted insert, original warranty card and import card.
Len
x
Len,
The only reason was to make the lens easier to store when not in use.
As you probably found out, the lens will not focus when the ‘goggles’ are removed - they not only alter the field of view but also change the linearity of the focusing. Even if you could turn the focusing mount without the goggles (there is a way to do this), rangefinder focusing would not be accurate.
Best,
Jan
I think it was because it was easier to manufacture that way. There existed a delightful case for the goggled Summarons (and the Summicron) which looked like half a hat box and could be carried by a strap over the shoulder. If you was carrying Leica gear, why not flaunt it?
The old man from the Age when Ladies Wore Hats
