klitton Posted November 15, 2008 Share #1  Posted November 15, 2008 Advertisement (gone after registration) I recently purchased a VIOOH viewfinder. Cosmetically it is in excellent condition and it works very well but the interior is a little hazy. Is this simple enough for me to take apart and clean or would I just screw it up?  Well, gotta go clean the house  I hope everyone is having a good weekend! Link to post Share on other sites More sharing options...
Advertisement Posted November 15, 2008 Posted November 15, 2008 Hi klitton, Take a look here VIOOH Cleaning?. I'm sure you'll find what you were looking for!
doubice Posted November 15, 2008 Share #2  Posted November 15, 2008 Hi,  If you are handy with jeweller’s screwdrivers and tiny screws, it should be a simple procedure. I have cleaned a few of these. Care should be taken when removing the screws on the back plate, so that you don't mark them - use a correctly sized screwdriver.  Once you remove the four screws on the back plate, the optical system will become accessible. If I remember correctly, there is a plate with a flat spring which holds the whole prism assembly in place and it is just a matter of removing it, cleaning and putting together again. There should be no surprises and no springs flying out not to be seen and found again……  Before proceeding with the disassembly, use Q-tip and clean the recessed front optics and the rear eyepiece - these often get dirty and further cleaning may not be necessary.  Good luck,  Jan Link to post Share on other sites More sharing options...
klitton Posted November 15, 2008 Author Share #3 Â Posted November 15, 2008 Thanks very much Jan. I do have the jewelers screwdrivers and I'm pretty good at fixing things. I tried cleaning the exterior optics but did not use the Q-tip approach. Its good to know that there are no microscopic springs to take flight across the room. Â Ken Link to post Share on other sites More sharing options...
klitton Posted November 17, 2008 Author Share #4 Â Posted November 17, 2008 Jan, Â I followed your advice and it was, as you said, a simple procedure. It turned out to be very easy and boy what a difference it made. My viewfinder is now much brighter than before and is dust and streak free. Â Thank you, Â Ken Link to post Share on other sites More sharing options...
doubice Posted November 18, 2008 Share #5  Posted November 18, 2008 Jan, I followed your advice and it was, as you said, a simple procedure. It turned out to be very easy and boy what a difference it made. My viewfinder is now much brighter than before and is dust and streak free.  Thank you,  Ken  Hi Ken,  Glad it worked out. I have re-surrected quite a few VIOOH's - all it takes is about 10 - 15 minutes and the finder is like new.... Well, almost like new....  Best,  Jan Link to post Share on other sites More sharing options...
