Guest Posted October 5, 2008 Share #1 Posted October 5, 2008 Advertisement (gone after registration) an meiner M8 möchte ich gerne abmachen. Am liebsten ohne Gewalt. Weis den jemand wie er befestigt ist. Danke schon mal. LG Franz Link to post Share on other sites More sharing options...
Advertisement Posted October 5, 2008 Posted October 5, 2008 Hi Guest, Take a look here Den Roten Punkt... . I'm sure you'll find what you were looking for!
sdommin Posted October 5, 2008 Share #2 Posted October 5, 2008 What's this about a damn rotten punk? Did you get mugged on the subway or something? Link to post Share on other sites More sharing options...
mhoutman Posted October 5, 2008 Share #3 Posted October 5, 2008 an meiner M8 möchte ich gerne abmachen. Am liebsten ohne Gewalt.Weis den jemand wie er befestigt ist. Danke schon mal. LG Franz ein wenig klebstoff Link to post Share on other sites More sharing options...
SJP Posted October 5, 2008 Share #4 Posted October 5, 2008 Aber doch nicht die M8 abmachen? Wenn man den Roten Punkt abmacht dan gibt das ein grosses loch Link to post Share on other sites More sharing options...
carstenw Posted October 5, 2008 Share #5 Posted October 5, 2008 There is a triangular hole underneath the dot, and the dot itself is made from very thin aluminium, so if you press exactly in the middle with something pointy (don't let it slip!), one of the edges should bend up and you can peel it off. Leica apparently does it like this. If this sounds too brutal to you, you can do what I did, and alternatingly push counter-clokwise and clockwise with a wooden match or toothpick, by pressing on the L and the a, until the glue gets tired and lets the dot fall off. This took me 15 minutes... Link to post Share on other sites More sharing options...
holgerf Posted October 5, 2008 Share #6 Posted October 5, 2008 There is a triangular hole underneath the dot, and the dot itself is made from very thin aluminium, so if you press exactly in the middle with something pointy (don't let it slip!), one of the edges should bend up and you can peel it off. Leica apparently does it like this. If this sounds too brutal to you, you can do what I did, and alternatingly push counter-clokwise and clockwise with a wooden match or toothpick, by pressing on the L and the a, until the glue gets tired and lets the dot fall off. This took me 15 minutes... Carsten - ich bewundere die Präzision und Raffinesse, mit der Du diese Sorte Probleme löst:) Wann baust Du in meine M8 den grauen Punkt ein? Link to post Share on other sites More sharing options...
