Pradovit Color 2 projector help needed
DrJohnGreg
I have 4 of these old beasts, 2 Pradovit Color 2 & 2 P2002 which I use for shows with a fader/changer unit. One of the Color 2s has a problem and I need some info. I have repaired them before, they get a bit of a hammering, usually mechanical problems with some of the 'flimsy' plastic parts breaking inside, but this time it is a electrical fault. Some of the wiring on the circuit board which controls the fading and changing has come adrift (dry joints from the factory!) and I don't know which pins the loose wires should to be resoldered onto.
Does anyone know where I can get a wiring diagram or similar? Or could someone with one of these projectors take their top off (if you see what I mean) and take a few pictures of the wiring?
