NEC Multisync vs NEC Spectraview
yadillah
I am becoming more and more confused!!
I think I want to buy a NEC 2490wuxi monitor, following what Sean Reid said about them. In Australia it is unavailable with the Spectraview profiling software.
I thought I would try and buy the software separately. This is impossible in Australia.
Now I have found that the Spectraview software will not work with the multisync monitor. All very confusing.
I can have the multisync monitor modified, but the price doubles.
My question is, is it really worth going for the Spectraview, or is the standard one OK. Also, I process a lot of black and white, and use a Macbook Pro.
I look forward to some comments.
AFAIK, it's virtually the same monitor.
The Spectraview series has it's own hardware profiling software and hardware (Eye One I think) and writes the profiling information directly to the monitor's hardware.
I'd suggest that you get a Multisync with a profiling solution not depending on the hardware (which makes IMO more sense anyway).
Just to clarify....if you buy the monitor itself in Australia and then order Spectraview from the states, NEC is saying the latter won't work with the former? Spectraview is certainly worth using (for the reasons I explained in the article) but if it becomes too much hassle you certainly could use a profiling system that writes to the computer OS rather than to the monitor itself. That's not ideal but it might work well enough.
Cheers,
Sean
Sean, thanks for your adcice. I have been told that the non Spectraview monitors are different to the Spectraview ones. In other words,if I manage to buy the Spectraview software, it will not work with the cheaper monitor.
The 2490 would still (I think) be a very good monitor, but will it be as good for b&w?
Because of where I live, I haven't the chance to preview them. Thanks,
Malcolm
I was in a similar situation and was very tempted after reading Sean Reids report on the monitor.It turns out that the NEC 2490 is not even available in England. I have finished up buying Eizo.I have to say that Sean`s review was to the same high standard as all his work.The cost of an annual subscription is about the same as 3 issues of the average mag. but with about 100x the content on equipment reviews. IMHO.
Brian
Malcolm
Hi Malcolm,
That's odd because my understanding was that SpectraView simply added a puck and software. I guess NEC themselves would have the authoritative answer on this. You might want to double-check with another NEC dealer about this. Perhaps the models differ from country to country?
Cheers,
Sean
Brian
Thanks very much Brian.
Cheers,
Sean
Hi Sean,
As far as I can find out here in Australia, Spectraview Profiling cannot be done on the standard monitor without some alteration to the hardware. This can be done, but the price goes from A$1600 to A$3100. Quite some difference!!
It appears that the monitors available here are shipped from Europe, and, if they are different to those in US, would explain why the Spectraview software is not available here. NEC America will only ship it in USA.
I am wndering if the standard 2490 is OK, (abeit not as good as the Specraview one), and if it would be OK for black and white. Thanks for your time.
Malcolm
Malcolm
Malcolm,
it is the same monitor - you just need to enter a "secret" menu and enable the "write to hardware" option. But then again, I failed at all tries to get the software legally from the US of A.
Hi Sean,
Malcolm
I'm surprised that they expect people in Australia to jump through all these hoops. The monitor itself is very good so maybe you'd want to try it with a traditional profiling program.
Cheers,
Sean
