DES Posted August 10, 2008 Share #1 Posted August 10, 2008 Advertisement (gone after registration) I have just taken my first shots with my M3 purchase. I have scanned the film (Velvia 50) and I am having difficulty getting any reasonable images in colour..I have CS3 and Lightroom what should I do to improve things...Thank you in anticipation. Des Link to post Share on other sites More sharing options...
Advertisement Posted August 10, 2008 Posted August 10, 2008 Hi DES, Take a look here Conversion Help!!. I'm sure you'll find what you were looking for!
Shootist Posted August 10, 2008 Share #2 Posted August 10, 2008 Just what do you mean "Reasonable Images" " In color"? Do you get reasonable B&W images? And just what do you mean "Reasonable"? Are the colors off? Or do all the color images look out of focus, Not as sharp as your B&W images? If it's the color then it could be the scanner, the developing, your monitor isn't calibrated correctly or a combination of all 3. Please post one of these un-reasonable images. If it's the focus then you may need to have your M3 CLA'ed. Link to post Share on other sites More sharing options...
DES Posted August 10, 2008 Author Share #3 Posted August 10, 2008 Hi Shootist...You got me ...I did not explain myself very well.!!! The monitor and scanner are fine..my b&w conversions are fine.. in general the clarity is fine, it is the colour that seems very poor. I have worked on a few and they have come up better but not to an acceptable standard..I just wondered if I was missing something and thought you guys woulkd know. Des... I understand that scanning images is a compromise, but this is not good. Link to post Share on other sites More sharing options...
adan Posted August 10, 2008 Share #4 Posted August 10, 2008 1. are those reddish/reversed shadow areas red in the slides (I've seen it happen - usually weak or failing E6 color developer) - or just in the scan. Check the slides against a really bright light before answering. 2. What scanner, and what settings? Very unusual to see white dust specks/threads in a slide film scan Link to post Share on other sites More sharing options...
Shootist Posted August 11, 2008 Share #5 Posted August 11, 2008 Do you have your scanner set for Slide (Positive) Film? And not Negative film. I believe it is a scanner setting or developer problem like Adan states. Just how does the slide look when viewed in bright light. Link to post Share on other sites More sharing options...
andybarton Posted August 11, 2008 Share #6 Posted August 11, 2008 I always scan slides as "images" in Vuescan. Works much better than scanning as a positive. Link to post Share on other sites More sharing options...
