acanalda Posted July 5, 2008 Share #1 Â Posted July 5, 2008 Advertisement (gone after registration) Hi to all, Â Suddenly the main speed dial of my Leica IIIf became completely "mad". I can turn it even without wounding the shutter. The dial turns but it seems to be "disengadged" The shutter release button works and the shutter operate but I don't know at what speed. Â Any suggestion? Â Regards, Â Arturo Link to post Share on other sites More sharing options...
Advertisement Posted July 5, 2008 Posted July 5, 2008 Hi acanalda, Take a look here In trouble with my Leica IIIf. I'm sure you'll find what you were looking for!
sabears Posted July 5, 2008 Share #2 Â Posted July 5, 2008 Hi Arturo,something is broken for sure. You have to send the camera to assistance,there is no other way. Â Cheers,M. Link to post Share on other sites More sharing options...
jhild Posted July 6, 2008 Share #3  Posted July 6, 2008 The main speed knob is fixed to the mechnics below with three very small screws, if they have become loose it is possible to turn the knob around with no other effect. Try to check that with a very small screwdriver. If the dial works again find the B setting and then reset the dial(by loosening the screws) to B with the shutter wound on. If that doesn´t work your camera is ready for service.  Jo Link to post Share on other sites More sharing options...
doubice Posted July 6, 2008 Share #4  Posted July 6, 2008 The main speed knob is fixed to the mechnics below with three very small screws, if theyhave become loose it is possible to turn the knob around with no other effect. Try to check that with a very small screwdriver. If the dial works again find the B setting and then reset the dial(by loosening the screws) to B with the shutter wound on. If that doesn´t work your camera is ready for service.  Jo  Exactly what should be done to try to remedy the problem. The screws are located in the side of the dial, in the knurled part.  Best,  Jan Link to post Share on other sites More sharing options...
acanalda Posted July 7, 2008 Author Share #5 Â Posted July 7, 2008 Thanks to all! Â Unfortunatelly, the camera needs to go to Solms. I have also discovered a big problem with the shutter. Â Thaks again for your replies. Â Regards, Â Arturo Link to post Share on other sites More sharing options...
