vikasmg Posted July 4, 2008 Share #1 Posted July 4, 2008 Advertisement (gone after registration) Not sure if this is an appropriate forum in which to post this question. I have just installed Aperture and imported SEVERAL folders and several thousand files from my drive - referencing them in their previous location (Yes it took a while!) Some of my files have the original names assigned by my cameras (eg "L1001684.DNG" and so on). I'd like to rename these to sumething more meaningful (like "20080618 - 001 - Coconut Lagoon Resort.DNG" etc). This is a fairly straightforward procedure in Lightroom. But there does not seem to be a way to rename the original files in Aperture. Thanks in advance for any assistance. Link to post Share on other sites More sharing options...
Advertisement Posted July 4, 2008 Posted July 4, 2008 Hi vikasmg, Take a look here Changing Master filenames in Aperture . I'm sure you'll find what you were looking for!
lxlim Posted July 5, 2008 Share #2 Posted July 5, 2008 From the menu bar; "Metadata" heading, select "Batch Change ..." Select the Version Name Format popup for a choice of different ways of renaming. You can always customise by selecting the edit at the bottom of the menu. Do one project at a time. Give Aperture some time in between renaming especially if you change your mind after renaming. I ran into some problems doing changes too quickly and had to rebuild the database. But maybe it was because the folder had a lot of files. Hope that helps. Link to post Share on other sites More sharing options...
